K9l3
Help with internet speeds
Hi vm i just got a xbox and the download speeds seem very slow a variant like 2mb to 14mb but contiously changing with big drops please help as never had problems with bt infinity.
  • 21.61K
  • 771
  • 3.09K
Re: Help with internet speeds
you say you just got the xbox. As will 10000's of other people today. Its possible that Xbox live is overloaded today and slow.
Can you run a speed test on a wired PC to check if the connection is slow?
K9l3
Yeh i think you are right i think i just did not realise they take so long to install
