Sammib70
Message 1 of 9
Frustrating broadband speed
My broadband has been very, very slow during peak times/evenings for a few months now. Help please.
Helpful Answers
  • 380
  • 12
  • 128
JPL8
Fibre optic
Message 8 of 9
Re: Frustrating broadband speed
Sammib70 wrote:
Is that 2018???? 😳😳😳😳😳
That's totally unacceptable. Vote with your feet and leave because a "review" date does not guarantee a fix. You could wait all that time and not see any improvement. Many utilisation faults have lasted over 2 years and there doesn't seem to be any incentives/sanctions to encourage VM to get on with fixing them.
You're also entitled to a discount on your bill for the duration of the fault should you decide to stay.
"Cable broadband is typically faster than copper-based services, but a significant minority of users experience severe slowdowns in peak times." — Ofcom, UK Home Broadband Performance, November 2016
All Replies
Sammib70
Message 2 of 9
I have superfibre 50
  • 111
  • 8
  • 39
voicon
Up to speed
Message 3 of 9
Hi Sammib70
If you have full speed during normal times it does sound like over utilisation of your area.
Are you testing on wired or wifi, remember Wifi can be worse during peak hours if you are in a populated area with lots of others using it, best to use wired to start with to narrow down the issue if Possible?
It would also be useful to post your hub stats just in case...
Open a browser window and input the URL 192.168.0.1 (192.168.100.1 if in modem mode) and this should open up the hub's management screen.   Do NOT sign in but simply click on Router Status and post here the Upstream and Downstream stats and the network log.
If these check out you can wait a few days for a VM support team member to check your network segment or call 150 to get an answer straight away (maybe), personally if you don't mind waiting I would for the forum team.
Cheers
Karl
  • 266
  • 21
  • 22
greeniegirl
Fibre optic
Message 4 of 9
hello
If you have an ethernet connection to a laptop or pc run the speed test on speed test.net and see what results you get...please make sure you have nothing downloading in the background of the device or other devices such as iPad's, game consoles etc running just so that you get a true reflection of the speed you are getting.  If you are not getting anywhere near 50mbps then ring 151 for assistance :-)
I am a virginmedia employee but all opinions are my own.
  • 10.82K
  • 308
  • 632
Message 5 of 9
Evening Sammib70,
I'm sorry to read you are experiencing slow broadband speeds during peak hours.
I've managed to locate your account and it appears you are affected by a high peak time traffic fault in your area which is causing slow speeds. The reference number is F004398551 and has a review date of 3rd January. As this is a review date it can be subject to change.
Sam
Sammib70
Message 6 of 9
Sammib70
Message 7 of 9
  • 380
  • 12
  • 128
JPL8
Fibre optic
Message 8 of 9
Jackson711
Message 9 of 9
I have had the same problem for a while. VM don't seem to be interested as I have contacted them regarding this and the response is along the lines of - you are using at busy times ! Not amused and it would appear that any time is a busy time.
