bill1989
Just joined
Connection not working on computer
I've had virgin media broadband for the last 6 months or so, it has always worked perfectly on my phone but on my computer i have problems.
The connection isn't as fast as it should be and the connection drops continually but always comes back in a couple of minutes. I thought it could be an issue with my wireless card so i bought an adapter and whilst it works better now it hasn't completely fixed the issue. It's the same on my laptop too.
What can i do to fix this problem? I'm not too concerned about the speed its more about the reliability
  • 5.66K
  • 291
  • 1.25K
Re: Connection not working on computer
If you are concerned about reliability - stop using wireless and wire up.
Without trying to sound blunt, that is the best solution.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
