Re: Removal of Virgin white inside box
lp92
I just called virgin and they said they dont have a department to un-install the white boxes that they fit to inner and outer wall.  I am trying to re-do my driveway and the workmen have told me that other people that they did work for were charged £250 for interferring with VM equipment.
I just spent an hour on hold with virgin.  I was finally told that they don't charge you and that we can go ahead and remove it.  I am still wary though.  What if i effect the connection to other neighbours
0 REPLIES 0
