doriswillis64
problems connecting to websites
Is there a problem with virginmedia internet as I have been unable to connect to my bank all day. Message on Virgin Site says there is a problem with new installations but earlier today it said there may be problem with connecting to other internet sites. Any ideas please? So frustrating I need to get online banking urgently
  • 35
  • 7
connbob
Re: problems connecting to websites
If it is only your bank's site that is down, it is more than likely that the bank's website is down. You could check by trying on a different internet connection (3G maybe?).
If you can connect with another connection, that would be strange. It is possible that your router has filtered it, yet unlikely, but worth checking.
Hope that helps!
Regards, Conn
(I do not work for VM, just like to help the community out, so I may be wrong Smiley Happy)
Homeworks + 300mbps, TiVo V6 Box, Talk Anytime
