Gemma1985
Wireless light
Can anyone tell me why the wireless light on my hub is flashing? Had nothing but problems with internet lately 😩
  • 2.96K
  • 378
  • 939
Re: Wireless light
It depends which hub you have.  On some a flashing wireless light can be normal, depending on the colour of the light.  There is a VM help page HERE that gives more info about the lights on the various hubs.
If you can give us a bit more information and describe the problems you have been having we might be able to help.
______________________
Scott
