67lions
Wifi extender
Trying to connect a bt wi fi extender to my hub and can't get it to sync. Anyone any suggestion ? Thanks Dylan
  • 16.52K
  • 1.38K
  • 3.38K
Re: Wifi extender
Hiya what model of hub do you have? Also what model of extender do you have, also what happens when you try and connect them any error messages?
67lions
Re: Wifi extender
Hey ... it's a virgin 3.0 hub and the extender is a netgear ex6210. In terms of error message I am trying to set it up by using WPS button on hub and extender but they don't seem to be syncing.... not really sure what I'm doing to be honest. Describes it as easy but just can't seem to get them to link up .... thanks Dylan
  • 16.52K
  • 1.38K
  • 3.38K
Re: Wifi extender
does it have the option to enter the passphrase aka wireless password?
