Meps
Wifi boosting
Hi,  just had VM installed two weeks ago. My speed is good, normally 180mbs, my wifi range is poor. Can I attach a booster to my system to improve range. I live in a town house and on the 3rd floor I get nothing. If a can, what's the best one?
  • 2.76K
  • 223
  • 843
Dave_cq
Trouble shooter
Re: Wifi boosting
Hi Meps,
Probably the best solution for your circumstances is to use Powerline Adapters like these ... https://www.amazon.co.uk/Devolo-Powerline-Starter-Adapter-Extender/dp/B00OZDO8RE/ref=sr_1_3?ie=UTF8&...
The master plug attaches to your hub via ethernet cable and plugs into a power socket.  The slave plug can be plugged into any power socket on the same mains system in any room and can transmit Wi-Fi or you can attach devices to it with ethernet.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
