  • 12
  • 5
angiejane_2000
Message 1 of 17
Wifi Light Flashing
We had Virgin tv, broadband and phone installed last week.  We were not left any instructions about the router so have no idea what all the lights mean as it was set up for us.  It looks to me like it is the 3.0 hub, I don't know if that is the latest one or not.  However, the wifi light (green) on the front is flashing continuously.  My internet is working, I have no problem with that, but do not know if this green light should be flashing or what it means if it is flashing.
Can anyone help please?
Thanks, Angie
  • 3.01K
  • 383
  • 952
Message 2 of 17
Re: Wifi Light Flashing
Hi Angie
I'm not familiar with the 3.0 Hub, but below is what the online help has to say about the lights on that model.  According to this the WiFi light should only flash if the WPS button has been pressed and then only for 2 minutes.  This may be a firmware bug, the 3.0 hub has a few of them.
Hub 3.0
The behaviour of the lights on the Hub 3.0 are different compared to other routers. The lights on the Hub 3.0 will only be lit if there is an issue, otherwise, with the exception of the Base LED, the lights will be off.
Front Panel
Here is a view of the front panel of the Hub 3.0. A guide to the lights can be found below.
Hub 3.0 Front Panel
WiFi Light
WiFi
When the Hub 3.0 has completed its start up procedure, the WiFi light will remain on for 2 minutes before going off. It will only remain lit if there is a problem with WiFi.
Internet Light
Internet
The internet light will flash when it is acquiring a connection and, once connected, it will remain on for 2 minutes before going off. It will also flash if the Hub 3.0 is downloading new software. Otherwise, the light will only remain lit or flash if there is an issue with the connection.
Phone Light
Phone
The phone light won't be lit as we don't currently provide a phone service through our Hub 3.0.
Base LED
The Base LED will be the only light that will stay on during normal operation.
Note: The internet light may be different from the image shown. It may say 'INTERNET' instead.
Note: With the current Hub 3.0 software there are some situations where the lights will remain on but this will change in future updates.
For example, if you turn off the wireless signal the WiFi and Internet lights will remain lit. Also, if the Hub 3.0 is in Modem Mode, the WiFi and Internet lights will remain lit.
Front panel WPS button
The WPS button is just above the Virgin Media logo.
Pressing the button for two seconds will prepare the Hub 3.0 to connect to compatible WPS devices. The WiFi light will flash green for 2 minutes during this process.
______________________
Scott
Disclaimer - I don't work for Virgin Media. I'm just another VM user trying to help out so my answers may be wrong :-) If you do like my answer please mark it as helpful as it may help others
  • 12
  • 5
angiejane_2000
Message 3 of 17
I had read that but thanks for posting it. Virgin left me no manual for my router or tito box so I have no idea whether it is OK for it to be flashing or what causes it to flash. Virginstow answer was well if your Internet is working don't worry about it. Unsure what to do now.
  • 301
  • 8
  • 28
Synthetic
Superfast
Message 4 of 17
Hi Angie,
I can't find it now, but I'm sure I've read somewhere that the wifi light flashing is a known bug in the current firmware on the SH3 and nothing to worry about Smiley Happy
It should be resolved once VM eventually roll out a better firmware for this hub!
Cristiano
Message 5 of 17
I am having the same problem as described: ininterrupt green WiFi light flashing, but internet working normally.
Hypothesis of a bug makes sense, but as it has passed 5 months of the conversation I would like to know if anyone has managed to fix the irritating permanent green on-and-off.
  • 12.48K
  • 353
  • 1.45K
Message 6 of 17
Hi Cristiano,
Apologies for your connection issues, and for our late response to your post.
I have checked the network segment to which you connect but can find no fault that result in your poor connection. However your Hub is reporting high downstream power levels which will need to be reduced by an engineer.
Please reply to my PM (purple envelope icon, top right of page) and I'll get an appointment scheduled in for you.
Once the power levels have been optimised, and if the problem persists, we'll investigate other potential causes.
Bye for now Smiley Happy
Jen
Brhojh6
Message 7 of 17
Hi the wifi light on my 3.0 hub has just started flashing green too. I've tried turning the hub off and back on but it still flashes. I can still get wifi so not sure if I should ignor it or not
Brhojh6
Message 8 of 17
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 9 of 17
Nothing to worry about if WiFi works. The topic has been done to death on the forums and a search on the term FLASHING should bring you to all the causes and work-arounds for those obsessed with turning it off!
Anibee
Message 10 of 17
I had same priblem on my hub for a few days then i notice a button below flashin wifi light which said pair wps so i pressed it and the flashing green lite has gone ....
