  • 9
denimknight
Superhub 2 connection drop out
Hi all,
Having issues with the Superhub 2.  It keeps dropping connection, it drops internet access and also internal network drops out.
Below is the screen shots for the upstream / downstream and upstream burst settings.  Is there anything I can do to sort this?  I currently have to switch the outer on and back off at least a couple of times a week.
Alex
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: Superhub 2 connection drop out
Hi denimknight,
Thanks for getting in touch to let us know about your issues with your broadband connection, I apologise for any inconvenience caused.
I have tested things from here and I noticed that all of your power levels are within the preferred ranges and there's no errors or time outs inside the Hubs logs.
Are you still having these issues? If so, how are you connected wired or wireless?
Is there any change to the Hubs light sequence when these issues occur?
Also, would you please include a recent copy of your Hubs logs for me to compare with the data we have here.
Take care,
Adam.
  • 9
denimknight
Hi Adam,
Yep, I'm still having problems.  At least once a night now I have to disconnect the router and reconnect it.  I'm connected through WiFi from multiple devices.  When the router starts acting up I lose both internet and internal network.
I think there's an issue with the actual router.  The lights seems to flash a lot more when this starts happening.  I've had to reboot the router 3 or 4 times tonight already!  Network log below, it doesn't seem to go back too far though, don't know what the default setting is or if it saves the logs somewhere else.
Hope you can help.
Alex
Date
Time
Error Number
Error Description
19/03/2017
23:56:49 GMT
66050310
Auth Success - Web login successful.
19/03/2017
23:56:49 GMT
66050310
19/03/2017
23:49:51 GMT
68010302
DHCP WAN IP - 82.39.*******
19/03/2017
23:48:46 GMT
68000407
TOD established
Time Not Established
82000200
No Ranging Response received - T3 time-out
82000200
82000200
82000200
82000200
84000510
Downstream Locked Successfully
19/03/2017
23:46:28 GMT
66050310
19/03/2017
23:46:27 GMT
66050310
19/03/2017
23:45:43 GMT
66050310
19/03/2017
23:45:43 GMT
66050310
19/03/2017
23:45:36 GMT
90000200
CSFR Detect - Expired Content Submitted ; LAN Interface
19/03/2017
23:45:36 GMT
90000200
19/03/2017
23:42:40 GMT
66050310
19/03/2017
23:42:40 GMT
66050310
19/03/2017
23:41:49 GMT
66050310
19/03/2017
23:41:49 GMT
66050310
[MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 9
denimknight
I've been having a look through the forum and the way most people seem to be getting this resolved is by buying their own router and setting the Superhub to modem mode.  This seems a bit ridiculous though.  Hopefully you're able to come up with a better solution.
Alex
  • 9
denimknight
I've just been on live chat and have had some conflicting information. Bhushan has said that there are signal issues and he's done an update.  He also said that the issue was overlapping channels...  This confused me a little, wouldn't an overlapped channel only effect either the 2.4 or the 5 GHz parts of the network?  The entire internal network gets taken offline, I'm not a network engineer but I would think that a channel overlap shouldn't take down both streams at the same time.
I could be wrong, but it sounded like Bhushan was basically just going down a stock checklist regardless of what my response was, he had it in his head that an router issue must be caused by X, Y and Z so that was what he was going to fix.
  • 9.58K
  • 321
  • 1.04K
Hello denimknight
I cannot help but notice that in the image you posted the downstream SNR is too low, we like to see it above 34dB, it may cause you some issues such as lag or freezing etc. It may have been a one off but at the moment I am unable to identify you from the forum details to confirm. I will send you a forum private message, please reply if you would like us to take another look.
Thank you
Nicola
Virgin Media Forum Team
