Alesi1989
Message 1 of 7
Superhub 2 VMDG485 Incorrect Password Again and again...
I have a VMDG485 SuperHub2.
I know I am using the correct password, yet regularly my wireless equipment is telling me I have the 'incorrect password'.
I even stand next to the router and type it in letter by letter.  Still no joy.
I have looked online and seen many others with the same problem - I have tried resets and other ideas all to no avail.  Any idea what else I can try?
Thanks in advance!
  • 20.52K
  • 541
  • 3.16K
Sephiroth
Message 2 of 7
Re: Superhub 2 VMDG485 Incorrect Password Again and again...
There is an odd bug/batch with SH2 where this happens. In the cases I have in mind, the only answer was for VM to send out a SH2ac.
There is a huge thread buried in the forums on this topic. The key identifier in this circumstance is that if you use something like inSSIDer to examine the advertised wireless signal you'll see your SH2 as reporting WEP security, which you are unlikely to have configured.
Alesi1989
Message 3 of 7
Oh.  How should I go about that then?  Is that a phone call to Virgin?
  • 20.52K
  • 541
  • 3.16K
Sephiroth
Message 4 of 7
The offshore support agents are a hit & miss affair at best but it's the fastest way to get attention.
Best to collect asmuch information as possible along the lines I've suggested. The big thread you should read is at:
http://community.virginmedia.com/t5/Forum-Archive/After-weeks-of-randomly-losing-wifi-connections-I-...
  • 3.98K
  • 202
  • 893
cybmole
Community elder
Message 5 of 7
try the original factory password. it may have factory reset itself & forgotten whatever you changed that to.
 or you can force a factory reset with a PIN I htink, then definitely the suppied password will work. I don't have that exact model but is there an original  password on a sticker on its case
Alesi1989
Message 6 of 7
I haven't changed the password so the one on the sticker is the correct one.  This afternoon it let me in again, then it changed its mind again half an hour later...
  • 3.98K
  • 202
  • 893
cybmole
Community elder
Message 7 of 7
is this thee wifi  password or the hub admin panel one
 in either case, changing them to ones you choose should be done and is a good test. if it keeps forgetting that also, you need a replacement hub
