Callum01
Message 1 of 5
Super Hub 2 wireless connection drop outs (2G and 5G) Error numbers (68000407, 68010302, 84000510)
We have recently been getting a lot of internet drop outs in both 2g and 5g. They have been extremely slow and very hard to use.
We have tried doing factory resets on the super hub but doesn't seem to do any difference.
If anyone could help that would be great!
This is our network log.
10/01/2017 20:49:48 GMT 10/01/2017 20:49:48 GMT Warning (5) 66050310 Auth Success - Web login successful.
10/01/2017 20:41:16 GMT 10/01/2017 20:41:16 GMT Warning (5) 66050310 Auth Success - Web login successful.
10/01/2017 20:40:40 GMT 10/01/2017 20:40:40 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 13:09:51 GMT 08/01/2017 13:09:51 GMT Error (4) 68010302 DHCP WAN IP - ###########
08/01/2017 13:08:47 GMT 08/01/2017 13:08:47 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
06/01/2017 20:32:34 GMT 06/01/2017 20:32:34 GMT Warning (5) 66050310 Auth Success - Web login successful.
06/01/2017 19:55:55 GMT 06/01/2017 19:55:55 GMT Warning (5) 66050310 Auth Success - Web login successful.
06/01/2017 19:55:17 GMT 06/01/2017 19:55:17 GMT Error (4) 68010302 DHCP WAN IP - #############
06/01/2017 19:54:12 GMT 06/01/2017 19:54:12 GMT Error (4) 68000407 TOD established
06/01/2017 19:44:25 GMT 06/01/2017 19:44:25 GMT Warning (5) 66050310 Auth Success - Web login successful.
06/01/2017 19:43:01 GMT 06/01/2017 19:43:01 GMT Error (4) 68010302 DHCP WAN IP - ###########
06/01/2017 19:41:57 GMT 06/01/2017 19:41:57 GMT Error (4) 68000407 TOD established
05/01/2017 18:28:47 GMT 05/01/2017 18:28:47 GMT Error (4) 68010302 DHCP WAN IP - ##########
05/01/2017 18:27:43 GMT 05/01/2017 18:27:43 GMT Error (4) 68000407 TOD established
03/01/2017 18:54:48 GMT 03/01/2017 18:54:48 GMT Error (4) 68010302 DHCP WAN IP - ###########
03/01/2017 18:53:45 GMT 03/01/2017 18:53:45 GMT Error (4) 68000407 TOD established
This is our downstream
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 299000000 267000000 275000000 283000000 291000000 307000000 315000000 323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 41 37 38 39 40 42 43 44
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) -6.20 -5.75 -5.70 -6.33 -6.23 -6.21 -6.56 -6.65
RxMER (dB) 37.09 37.09 37.09 36.84 37.09 37.09 36.84 36.84
Pre RS Errors 914 3608 454 686 335 531 353 404
Post RS Errors 293 287 281 283 297 357 323 301
This is our upstream
Upstream   US-1 US-2 US-3 US-4
Channel Type N/A N/A 2.0 2.0
Channel ID N/A N/A 5 7
Frequency (Hz) N/A N/A 37600000 24400000
Ranging Status Other Other Success Success
Modulation N/A N/A 16QAM 16QAM
Symbol Rate (Sym/sec) N/A N/A 5120000 5120000
Mini-Slot Size N/A N/A 4 4
Power Level (dBmV) N/A N/A 52.00 52.00
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
Many Thanks
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 9.34K
  • 797
  • 1.96K
Message 2 of 5
Re: Super Hub 2 wireless connection drop outs (2G & 5G) Error numbers (68000407, 68010302, 84000510)
Your downstream power levels are too low and your upstream is running a tad warm.
If you have a barrel shaped attenuator screwed to the back of the hub at the end of the coax cable you can try removing it.
However, there is nothing showing in the logs indicating  the connection between the hub and VM's servers is dropping. You may have a wireless problem as well which is causing the wireless to drop out. Usually changing the wireless channel the hub is broadcasting on can help. It may be wise to get the power levels sorted before going to deeply into the wireless diagnostics.
  • 14.44K
  • 641
  • 1.46K
Moderator
Moderator
Message 3 of 5
Hi Callum01,
Welcome to the forum, I've just checked your connection and agree with Griffin that both your up and downstream power levels need some attention.
I've just sent you a private message to arrange a technician visit to adjust this for you.
To view your messages just click the envelope at the top of the page.
JustJosh1e
Message 4 of 5
Were having the same issue can you or someone please send me a pm ?
JustJosh1e
Message 5 of 5
