smcgrath
Settling in
Slow to resolve DNS and slow to connect
I recently changed my SuperHub from Modem mode to providing DHCP.  Throughput OK, but it slows down dramatically after a while and I need to reboot.
I saw another post that identified a problem with the following reply from your team : "I'm sorry to hear that you're experiencing slow DNS resolving / connections on your browser.  I've run a couple of checks and it does look like your hub is reporting high power levels across the upstream channels, this may well be affecting the connection.
I'd like to book an engineer to sort the power level issues in the first instance. I'll send you a PM (purple envelope, top right) so we can arrange a suitable time slot. Get back to me when you get chance and I'll book something in asap."
Can you do remote diagnostics?
SuperHub
Software Version   "V2.39.02"
Hardware Version   2.00
  • 10.03K
  • 332
  • 877
Hero
Re: Slow to resolve DNS and slow to connect
smcgrath wrote:
Well...yes that is why you put it in modem mode and then add your own router
smcgrath
Settling in
Are you saying that the superhub is not a very good router?
  • 10.03K
  • 332
  • 877
Hero
You can ask for another model which is some what better but your super hub is better in modem mode as you know.
