3 weeks ago
I have had a solid red light on my virgin media hub for over well over 4 months. I’ve also been having issues with my WiFi dropping on a regular basis. I have called virgin media a few times and they mentioned it was an update and it would disappear once downloaded, we have also had a WiFi pod delivered for better coverage, but this hasn’t helped. I have done a reset of the wifi router recently and have taken out the wires and plugged them in again. Unfortunate the red light is still coming up.
My daughters cannot get a signal upstairs and are using all their data on their mobile phone contracts!!
3 weeks ago
Hi @Burnleyfc1,
I'm very sorry to hear that you've got a constant red light on your Hub along with some connection issues. If you haven't done so already, please follow these steps.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the issue remains after following the above, please respond to the private message that I'll be sending to you shortly and we can go from there with this.
