murshed2010
Possible to record device connection history?
Hi, is there a log of when devices connected and disconnected from my router and if not is there anything i can do to make the router or a program (I have a laptop that runs as a 24/7 gaming sever) to log this down? I want to know when my brother comes in and out of the house and also see if hes using the computer at night instead of sleeping.
  • 10.82K
  • 309
  • 632
Re: Possible to record device connection history?
Hi murshed2010,
With the router it will only show you the devices that are connected at that time, whether that is wired or wireless. It won't show any previously connected devices or give a log, unfortunately.
If you didn't want anyone to use the laptop, you could add a password protection to the device so only you can gain access.
Hope this helps
Sam
murshed2010
No one has access to the laptop except from me, when I mentioned the laptop i meant to mean that I can run a program on it (if there is one) to log down connections because it is running 24/7 anyway.
