Johnmcmuray88
No valid IP Address. Need help
I cant connect to the internet on my laptop. Mobile phone is fine. Message reads 'Wireless Network Connection doesn't have a valid IP Address. What do I do to sort this?
  • 16.46K
  • 1.37K
  • 3.36K
Re: No valid IP Address. Need help
hiya @Johnmcmuray88 is this a work laptop?, since it might be possible the laptop has been configured to use a static IP address that isn't compatible with the hubs subnet. if you take a look at http://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/ just choose 'automatically'
