  • 5
Hairyyy
Message 1 of 9
Insane Ping Issues.
Albiet I use wireless my Ping has been perfect for the last couple years or so and something has happened in past two weeks changing it. I used to have some form of issues with ping but it do able I could play games any time of day and it'd be fine. But now I get in a game for example of Siege and ping spikes up to 8000 and I'm kicked off the game. Not offline just off the game.
I have no problems what so ever with connecting to certain websites or downloading things its only ping issues.
With Cable in on a speedtest I hit 9ms , 150mbps down, 10 up
Wireless like 12 ping, 20mbps down and like 0.7 up
  • 8.61K
  • 551
  • 2.38K
Message 2 of 9
Re: Insane Ping Issues.
post a treaceroute to the server you are having issues with...
  • 5
Hairyyy
Message 3 of 9
Unable to locate server but this is what I got when I did it to google
http://puu.sh/u6fgH/52ee502291.png
  • 8.61K
  • 551
  • 2.38K
Message 4 of 9
That shows no issues- but Id expect that given you've said its just certain games you are having issues with.
Are you having the same issues with anything else?
We really need to see a traceroute to a server/site you have the issue with to diagnose much more- if that's not possible, its down to generic advice - if its just on one game, speed-tests are okay and latency to other servers is fine - its the game servers.
  • 5
Hairyyy
Message 5 of 9
Monitor - http://puu.sh/u7mw5/f9b3ecaf2d.jpg
Using Wired Connection - http://puu.sh/u7mw5/f9b3ecaf2d.jpg
Using Wireless - http://puu.sh/u7mBU/ba2e4c2f8f.jpg
During the one game that I normal play using wireless - (The in game server is neu - north Europe) Game is Rainbow Six Siege again unable to locate servers.
http://puu.sh/u7naQ/af2224888e.jpg
http://puu.sh/u7nha/4d88883b05.jpg
http://puu.sh/u7nAO/c496802225.png
Battlefield 4 - 600-1000 ping using Wireless.  Played a game after this on wired sat on 30 ping the whole game.
http://puu.sh/u7oab/94b1df65d3.jpg
http://puu.sh/u7nVb/2e98a264e4.jpg
http://puu.sh/u7odc/c5d911d866.jpg
I doubt would be game servers as I same to be the whole one experiencing it out of 3 friends in the same area using virgin media?
 Edit: Ports according to https://support.ubi.com/en-gb/Faqs/000023138/Connectivity-issues-in-Rainbow-6-Siege
Uplay PC:
TCP: 80, 443, 14000, 14008.
Game Ports:
UDP: 6015
  • 5
Hairyyy
Message 6 of 9
Monitor link was wrong - https://puu.sh/u7mqD/d37d65deb7.jpg
  • 8.61K
  • 551
  • 2.38K
Message 7 of 9
Your BQM isnt populated because you haven't enabled reply to IMCP...
Without wanting to sound patronising, its irrelevant what is happening with your friends on VM- that just proves its not a generic VM problem. We need to see your route to the server to diagnose what going on? Do you know how to run a traceroute? Do you want me to post some instructions?
  • 5
Hairyyy
Message 8 of 9
Cmd prompt > tracert ip/web address?
And not at all. I appreciate you even replying I'm just clueless on what has happened.
Yes please do
  • 8.61K
  • 551
  • 2.38K
Message 9 of 9
Thats right (how to run a traceroute) -
you need the IP of the server you are connecting to when you see the issues- the game companies website may have it listed, or at least an IP suitable for using to ping or traceroute to.
Some games will have the IP address of the current server available on an ingame console.
