Sianw89
Green flashing base led
Hi! Got Virgin installed yesterday and we have a constantly green lit wifi symbol and green flashing base led. Any ideas?
  • 9.49K
  • 652
  • 1.81K
Re: Green flashing base led
sounds like its not activated - was it a self install or by a VM tech - either way thats the first thing to check - takes VM a week or so to get to threads so you need to ring and get some help
____________________
Tony
Sianw89
It was working fine last night and this morning?
  • 9.49K
  • 652
  • 1.81K
ahhhhh ok - may be no more than maintenance - the lights are telling you its offline - it should come back on its own - a call might get you some info
Tony
