WilsonS1
Devices and wifi
Why can't my new kindle paper white find my home wifi ? All other devices do ... No issue with the kindle
Locates all others along the street !
  • 5.5K
  • 205
  • 326
Re: Devices and wifi
Hello WilsonS1,
Welcome to the community Smiley Happy
We're you able to find your wifi signal? it will say on the hub what it's called unless you have changed the name.
Please let me know if you're still experiencing any issues.
Kind regards
Rose
  • 1.87K
  • 175
  • 338
J0hn
Super solver
Check if the paper White uses 2.4 and or 5Ghz wifi, then if possible set it to about
To add a Wi-Fi network to your Kindle Paperwhite, follow these steps:
If necessary, turn on your Kindle Paperwhite.
Tap Menu→Settings.
From the same screen, tap Wi-Fi Networks.
If Wi-Fi is not turned on, you will get a message asking if it should be turned on. ...
Select the network to which you want to connect.
