  • 104
  • 5
BluesFanUK
2.4GHz Wifi constantly dropping out?
I'm connected to Ethernet and for the most part that's been fine over the past month or so. The wifi is atrocious though. It's been cutting out intermittently over the past few weeks, a full reboot seems to temporarily fix it, but then it'll keep cutting out/coming back on. It's set to auto on the channel btw. I did notice the 2.4GHz blue icon on the Superhub 2 flashes, while the 5GHz blue icon doesn't, and seems more stable.
What's going on? Also why does the Wifi take an age to come back on but the Etherent connects fairly quickly once rebooted?
  • 1.28K
  • 95
  • 235
stevedh2
Knows their stuff
Re: 2.4GHz Wifi constantly dropping out?
prob with getting a wifi scanning app and checking to see how crowded the wifi channels are in your vicinity, also do you have any baby monitors or other equipment that can cause wifi interference ?
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Are the devices that cut out 5GHz enabled as well as 2.4GHz?
Do you have separate WiFi names for 2.4GHz & 5GHz?
