Audio Sync problem with new 360 box
MrUnhappy2
I have had the new V6 /360 box for 10 days and have problems with the audio synchronisation.
My TV is a 4 year old 50" Sony Bravia with Sony sound bar. When I had the Tivo and the model before it I never had any problems.
The audio is okay with the soundbar off but when using the soundbar the audio drifts after about 5 mins. I have tried Dolby On/Off settings , audio delay set to 20m/sec and follow audio On/Off. All work for 5 mins then drift.
I have telephoned Virgin on 2 occasions the 2nd time getting through to their 2nd tier support. Went through all the power down re-boot etc  but still the same issues.
Anyone else have this problem and any suggestions?
Thnks
1 ACCEPTED SOLUTION
Accepted Solutions
After advice from 3 different tech guys on the phone I finally got one who talked me through how to solve the problem So the fault is fixable it's just getting the right agent to talk you through it
359 REPLIES 359
goodykpg
Hi, I have same equipment sony tv and sound bar , sound disappears completely once or twice every hour . Switch off sound bar and back on sound back .Like you tried new leads and every setting  on box  ,rebooted bar and tv still same . No fault if box off and just tv on  & blu Ray on . Never had this fault on V6 . Got to be glitch in box  , not impressed as Virgin don't seem to be interested about fix.
Thanks for your reply. Yes like you, Virgin do not want to know. There is obviously a software issue with the V6 but they will not admit it
Good luck but am now thinking of moving to BT. They are also cheaper with a better package.
Wulbury
I also am having problems with audio sync.I have a 3 year old Philips TV Ian getting this problem on all channels without using soundbar It is not a TV fault as I never had any problems with V6 box
Virgin told me that they had fixed fault online but 2 hours later fault reappeared. Also when I switch on after been off at mains I have to switch TV off and on twice
Hi Wulbury,
Looks like we are not alone !
Sorry to see we've been unable to fix this on our end.
Have you perhaps spoken to the manufacturer of the sound bar to see if they're aware of the problem and have a workaround to fix this?
Kindest regards,
David_Bn
Hi David,
Thanks for your reply but as my system worked okay with the old Tivo and predecessor it has to be a problem with the 360 box.
Virgin do not want to know.!
I always try to sync to a live broadcast like the news, you can nearly get the presenter in sync but if they show a video interview on the program the sound will be out of sync on the video, I know there can be technical reasons for this but quite often it is a long way out. Like you I never had a problem with the Tivo V6, also I like the way they tried to deflect the problem to your sound bar which was ok before the 360.
MrUnhappy2
Hi Roy
Thanks for your input.
I agree about synchronising to a live broadcast e.g. the news presenter. Problem is that I can sync it various ways but all drift after a few minutes.
Cheers
I have just switched to 360 today and all virgin channels are out of sync
Audio delay only works one way is there any way to add minus delay
No issues with sync using apps like netflix
