pwellock's avatar
pwellock
Hub red light
I have a constant red light on my hub. Like others I have rebooted and reset but this does not resolve the issue. Please could someone from Virgin support contact me?  Thanks
    If the Hub is a Hub 3 and the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Paul_DN's avatar
    Paul_DN
    Hi pwellock,
    Thank you for reaching out to us in our community and welcome, we are sorry to hear you have a constant red light on your Router and that a reset hasn't helped, so I can help I have sent you an invite into a private chat, please look out for a white envelope to accept.
    Paul.
