Samorhan's avatar
Samorhan
Hub 3 constant red light
I have a constant red light on my hub 3 tried all the fixes and it’s still on any ideas?
  • HI Samorhan thanks for your post here although we're sorry to hear of your concerns raised.
    Can you please try the following:
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If this doesn't work, please let us know.
    Many thanks
    Many thanks
    • Samorhan's avatar
      Samorhan
      I have tried all of those and reset it too it’s still displaying a solid red light unfortunately.
      • Ayisha_B's avatar
        Ayisha_B
        I'm going to pop you a PM 📩 now so we can arrange an engineer visit and have the Hub replaced.
        Speak soon!
  • Ayisha_B's avatar
    Ayisha_B
    Just updating the thread Samorhan
    The engineer visit was booked so the Hub can be replaced.
    Keep us posted 😃
  • I am currently having this exact issue with my Hub 3. Red light, warm to the touch and intermittent connectivity. It has been like this over a month. Tried the online chat facility and it makes me go over the same questions with a bot before connecting me to an advisor and cutting out. I’m losing the will to live.
    I have done the reset multiple times as well as rebooting. The hub is in the same place it has been for years since it was installed by yourselves.
