Samorhan
3 months agoJoining in
Hub 3 constant red light
I have a constant red light on my hub 3 tried all the fixes and it’s still on any ideas?
- 3 months ago
HI Samorhan thanks for your post here although we're sorry to hear of your concerns raised.
Can you please try the following:
• Then use the power switch to turn the unit back on. The Hub should now operate normally.If this doesn't work, please let us know.
Many thanks
