Samorhan's avatar
Samorhan
3 months ago
Hub 3 constant red light
I have a constant red light on my hub 3 tried all the fixes and it’s still on any ideas?
  • Tom_W1's avatar
    3 months ago
    HI Samorhan thanks for your post here although we're sorry to hear of your concerns raised.
    Can you please try the following:
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If this doesn't work, please let us know.
    Many thanks
