on 09-03-2024 19:09
We have been experiencing slow speeds for our Hub 4 wi-fi, supposedly on the 1GB package. We are seeing speeds of about 150-200mbps.
Regardless of this, I thought the slowness could have been caused by some hub settings, so I did a factory reset (3 times now, firstly via settings page, and then twice using the reset pin on the hub itself), and I am now unable to load the hub settings page post-login. It times out and says the page is unresponsive. Due to this I now cannot change my SSID or passwords, or split out the networks into 2G and 5G channels.
Any help would be appreciated.
Answered! Go to Answer
on 04-05-2024 09:02
Im having same issue can’t access settings page also connection always drops done hard reset and no luck I have to reboot modem all the time
on 06-05-2024 15:38
Hi @damian-meller77 👋.
Thanks for reaching out to us and welcome to the Community Forums. Apologies for the issues that you are having with the Hub 4 settings, we are aware this is causing an issue for a few customers. If you can join me in a private message so that we can get this resolved for you. Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
2 weeks ago
Hello,
I am also experiencing the same issues and can not login to router settings on Hub4, from what im reading its quite a common problem - would it be possible to get a replacement or the Hub5?
Thanks again 🙂
2 weeks ago
Hi @Daniel251087 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the issues you're experiencing 😔
I can see you've been in touch with the team. Did they manage to book an appointment for you?
Regards,
Daniel
2 weeks ago
Hi @Sabrina_B how can I receive the same support? My Hub 4 has broken and it’s affecting my security and safety at home.
2 weeks ago
Hi Beth I am having exactly the same issue. Given I am paying close to £100 per month I would expect a Hub 5 sent out - is this something you can arrange?
2 weeks ago
Please PM me too - exactly the same issue and my home safety is now a huge concern.
a week ago
i had the router replaced which was brilliant - but now when i enter password to the hub it is saying wrong password which i have copied from the hub
a week ago
I am having exactly the same problem, can't access the router via a browser and have tried hard reset. Please can someone help me get this issue sorted.
Monday
Hi @TooManyShoes,
I've responded to your other post about this earlier today. We'll continue to assist you from there with this going forward.
