Broadband dropping out and high latency DA5
Hi, I am trying to raise a fault online for my poor broadband connection that shows on the below graph starting around 05:00 9/10.
I've checked all connections and re-started the hub but no change.
Logs from router below showing recent events,
If somebody could help please with any connection checks this would be great.
0-10-2024 15:51:36 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 5 6 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-10-2024 15:51:36 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-10-2024 15:51:13 | warning | MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Cable Modem StatusItem Status TypeChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.0 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
3.0 Downstream channels
1 | 306000000 | 2.7 | 41 | QAM 256 | 22 |
2 | 138000000 | 2.9 | 41 | QAM 256 | 1 |
3 | 146000000 | 3.2 | 41 | QAM 256 | 2 |
4 | 162000000 | 2.9 | 41 | QAM 256 | 4 |
5 | 170000000 | 2.8 | 41 | QAM 256 | 5 |
6 | 178000000 | 2.6 | 41 | QAM 256 | 6 |
7 | 186000000 | 2.7 | 41 | QAM 256 | 7 |
8 | 194000000 | 2.9 | 41 | QAM 256 | 8 |
9 | 202000000 | 2.9 | 41 | QAM 256 | 9 |
10 | 210000000 | 3.1 | 41 | QAM 256 | 10 |
11 | 218000000 | 3.2 | 41 | QAM 256 | 11 |
12 | 226000000 | 3 | 41 | QAM 256 | 12 |
13 | 234000000 | 2.8 | 41 | QAM 256 | 13 |
14 | 242000000 | 2.7 | 41 | QAM 256 | 14 |
15 | 250000000 | 2.8 | 41 | QAM 256 | 15 |
16 | 258000000 | 3 | 41 | QAM 256 | 16 |
17 | 266000000 | 3.1 | 41 | QAM 256 | 17 |
18 | 274000000 | 2.9 | 41 | QAM 256 | 18 |
19 | 282000000 | 2.9 | 41 | QAM 256 | 19 |
20 | 290000000 | 2.9 | 41 | QAM 256 | 20 |
21 | 298000000 | 2.8 | 41 | QAM 256 | 21 |
22 | 314000000 | 2.6 | 41 | QAM 256 | 23 |
23 | 322000000 | 2.5 | 41 | QAM 256 | 24 |
24 | 330000000 | 2.3 | 41 | QAM 256 | 25 |
25 | 338000000 | 2.3 | 40 | QAM 256 | 26 |
26 | 346000000 | 2.2 | 41 | QAM 256 | 27 |
27 | 354000000 | 2.3 | 41 | QAM 256 | 28 |
28 | 362000000 | 2.4 | 41 | QAM 256 | 29 |
29 | 370000000 | 2.2 | 41 | QAM 256 | 30 |
30 | 378000000 | 2.1 | 41 | QAM 256 | 31 |
31 | 386000000 | 2.2 | 41 | QAM 256 | 32 |
1 | Locked | 41 | 521 | 0 |
2 | Locked | 41 | 997908 | 519867 |
3 | Locked | 41 | 1290154 | 728186 |
4 | Locked | 41 | 3756284 | 1151791 |
5 | Locked | 41 | 92754105 | 15115032 |
6 | Locked | 41 | 96344031 | 28494165 |
7 | Locked | 41 | 55877376 | 1789676 |
8 | Locked | 41 | 38265 | 26 |
9 | Locked | 41 | 3432 | 22 |
10 | Locked | 41 | 2329 | 24 |
11 | Locked | 41 | 1278 | 13 |
12 | Locked | 41 | 1647 | 19 |
13 | Locked | 41 | 3746 | 13 |
14 | Locked | 41 | 2066 | 19 |
15 | Locked | 41 | 788 | 13 |
16 | Locked | 41 | 632 | 18 |
17 | Locked | 41 | 311 | 23 |
18 | Locked | 41 | 217 | 15 |
19 | Locked | 41 | 571 | 1 |
20 | Locked | 41 | 1908 | 6 |
21 | Locked | 41 | 1964 | 21 |
22 | Locked | 41 | 68 | 0 |
23 | Locked | 41 | 52 | 0 |
24 | Locked | 41 | 57 | 1 |
25 | Locked | 40 | 57 | 0 |
26 | Locked | 41 | 49 | 0 |
27 | Locked | 41 | 47 | 0 |
28 | Locked | 41 | 39 | 0 |
29 | Locked | 41 | 41 | 0 |
30 | Locked | 41 | 29 | 0 |
31 | Locked | 41 | 44 | 0 |
3.1 Downstream channels
33 | 92 | 4K | 1800 | QAM 4096 | 1128 |
33 | Locked | 41 | 0.7 | 631529023 | 0 |
3.0 Upstream channels
0 | 49600000 | 49.5 | 5120 | QAM 64 | 5 |
1 | 43100000 | 48 | 5120 | QAM 64 | 6 |
2 | 36600000 | 46.3 | 5120 | QAM 64 | 7 |
3 | 30100000 | 51.5 | 5120 | QAM 64 | 8 |
4 | 23600000 | 52 | 5120 | QAM 64 | 11 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
12 | 10.4 | 45.2 | 2K | QAM 256 |
12 | OFDMA | 208 | 74000000 | 0 | 0 |
Before the Tech visit - can you try a little experiment....
___________________________________________
There is another possibility, there have been several threads on here recently where similar BQM latency/packet loss problems were eventually pinned down to a dodgy piece of connected kit affecting the connection . Bad connectors on ethernet cables, NAS Drives and faulty network switches being high on the list of culprits.
What I advised was... if you run the BQM for 24h to get a picture of the issues (you have done this) - and then unplug all the ethernet cable connections from the Hub and just let it run - overnight is best - then in the morning look at the BQM and see if it has cleaned up. If it has - plug the devices back in one at a time for an hour or two until the problem reappears and that should indicate where to look for what is causing the issues - Start by changing to new good quality ethernet cables, minimum of Cat6a spec.Examples of this issue...
See message 21 in the first thread, 13 in the second and 5 in the third and 5 in the 4th
https://community.virginmedia.com/t5/Networking-and-WiFi/Internet-connection-dropping/td-p/4781287/page/3
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-Connection/td-p/5069984/page/2
https://community.virginmedia.com/t5/Speed/Issues-in-GU22-area/m-p/5400109#M307543
https://community.virginmedia.com/t5/Networking-and-WiFi/BB250-Connection-dropping-frequently/m-p/5451242#M570038
