DebJon's avatar
DebJon
Dialled in
Record of incoming calls
I urgently need to find out the date I received a certain incoming call; is there anyway of doiing this please? TIA
  • Does your telephone handset record any incoming information? Depending on how long ago you want to go back, some information may be recorded there (although often the number of calls is limited and old calls are overwritten by new calls when the call list is full).
  • Hello DebJon,
    Welcome back to the community and thanks for taking the time to post here on the forums. Unfortunately, we don't keep any records of incoming calls to your landline. We only keep records of outgoing calls.
    Kind Regards,
    Steven_L
    • DebJon's avatar
      DebJon
      Dialled in
      Oh, that's frustrating but thanks for getting back to me.
  • goslow's avatar
    goslow
    • DebJon's avatar
      DebJon
      Dialled in
      Thanks for responding. Unfortunately I don't think it does but will hunt down the instruction book to double check; will get let you know if it does!
      Thanks again.
