golf20vT's avatar
golf20vT
Dialled in
Virgin Media Hub 4 Password Problem
So,
Been having problems for a while, engineer came and renewed the Hub 4 and on the Bottom is a Wifi password
The same password is printed on some stickers he gave us, but when i try to use it they don't work?
the only way to link to the hub by laptop is by pushing the WPS button
but our TV and Phones don't have this option
any ideas please
Thanking you in anticipation
    Have you tried to login to the Hub via http://192.168.0.1/ using the Hub Password,
    then verify the Hub's Wi-Fi passwords are set as expected from the labels.
    Might be best to use a network cable connected laptop.
  • jbrennand's avatar
    Try this...
    Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
    The two Passwords for hub settings and wifi will reset to those on the base sticker so use them to log in and also change them back to what they were or you want them to be.
