10 months agoVery Insightful Person
Try this...
Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time.
The two Passwords for hub settings and wifi will reset to those on the base sticker so use them to log in and also change them back to what they were or you want them to be.
Related Content
- 2 years ago
- 4 months ago
- 2 years ago
- 3 months ago
