Mark102's avatar
Mark102
Technical fault after planned works
I live in the TW16 area and after planned works yesterday my hub will not reconnect. Has anyone else got the same issue, or is there a known problem that is still be worked on?
  • jbrennand's avatar
    see this
    ______
    First thing is to check for any “known network faults in your location - Look in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    • Mark102's avatar
      Mark102
      Thanks, but it seems to be an ongoing network issue on the VM side…I just hope they resolve it soon, already two days in!
      • John_GS's avatar
        John_GS
        Hi Mark102
        Sorry to hear of the issues you've had.
        There was an area issue on the weekend which is now resolved.
        However, you do need a tech visit as your downstream power levels are out of spec.
