Technical Fault You Won't Fix ??
Before I contact disconnections (I'm that angry), please give a a sanity check her !
I has an issue with my home hub 2, with poor wifi and red power light all the time.
I followed process, hub was confirmed faulty and a replacement dispatched.
I fitted new hub, and had nothing but agro with setup initially requiring a reset multiple times before sort of working.
I work from home, and have two PC's connected by two different Cat 5 cables to the ethernet ports on the hub.
It was immediately obvious that these PC's were having issues connecting to the internet when first switched on, and can take at worse up to 5 minutes to establish a connection.
Whilst this is going on I will point out that wifi connections are available, its only the ethernet connections that are affected.
Old hub didn't have this error, new hub does !!
Two different PC's on two different Cat5 cables affected, so its NOT my equipment !
Once connection to the internet is made, it will maintain the connection for the duration of the session.
However if a PC is switched off or put to sleep, we have to repeat the wait to get a connection again, with all tests reporting no internet connection.
I'm assuming these hubs are referbed units ?
This one has an issue that I didn't have until this hub was connected.
Support claim they can't see an issue (as stated, one it does connect its stable), so only suggestion is an engineer visit at my cost !!
So you sent me a replacement hub that has an issue, and I have to pay for someone to come and look at it !
Best bit is, even if they confirm the hub is faulty, apparently I STILL have to pay for the engineer visit !
How can this be right ??
I asked for escalation to team leader or manager, basically refused.
I have worked in customer service industries for 30 years, and this is NOT customer service.
Before I decamp to Sky, am I right in thinking this simply isn't right ??
Hi Andy-2608 👋 Thank you for getting back to us and for continuing to update the thread!
I can appreciate your frustration given your experience with the fault, and that you have already had a replacement.
I'd like to offer some help, so I'm going to send you a PM to confirm a few details to investigate further and offer support - this includes discussing the complaint further along with the resolution.
You can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
