Andy-A-P's avatar
Andy-A-P
Internet connection Issues
The ethernet connections from my hub have stopped working. This includes the TV set top box - the apps cannot connect as it says there is no ethernet connection. I also have a PS5 connected via ethernet with has no connection either.
The Wi-Fi is very patchy and keeps losing connection & reconnecting on all devices.
I have restarted the hub a few times now, switched it off at the wall etc. with no improvements.
I have tried the online & Virgin connect app troubleshooters with no luck, just take me circles and doesn't resolve anything.
How do I speak to an actual person to get a resolution?
  • This is now resolved. It was resolved by speaking to customer service (0345 454 1111) and they sent a "hit" to my hub to reboot it. This fixed both my ethernet and Wi-Fi issues.
    I had tried the solution found here on the forum, of disconnecting the ethernet cables and doing a hard reset by pressing the reset button under the hub for 60 seconds, leave for 5 minutes and reconnect the cables. This one didn't work me me
    • ruairi_o's avatar
      ruairi_o
      Lucky you… I’m on my third Hub in less than 6 months that’s spectacularly failing to correctly assign IP addresses, resulting in ‘connected, no internet’ errors on a random selection of devices - WiFi and Ethernet.
      I could really do with a ‘hit’ of whatever they gave your hub!
