Vim1965's avatar
Vim1965
3 months ago
Hub 5 keeps disconnecting
Afternoon
I have a Hub 5 with 3 pods but I regularly loose connection.
The hub has to be reset nearly every other day! Even done a factory reset to see if would help but no joy...
Is the Hub 4 more reliable?
  • Thank you for your reply.
    Had a mesh but VM would not support as router was in modem mode.
    VM supplied the pods to improve my coverage but now finding the hub is proving problematic.
    Any advice would be great.
  • Since December my internet and landline have been disconnecting throughout the day.  Before this it was fine.  I have Hub 5.  Every time I try and contact Virgin Media by internet or telephone it loses the connection so I get nowhere.  Very frustrating.  Any advice would be appreciated.
    • Nathan_B's avatar
      Nathan_B
      Hi sheila35 I'm afraid our community forum is about to enter a period of downtime, so we’re unable offer further support here for the moment.
      But don’t worry, our team is still available and ready to help you through our other support channels. You can reach us via private message on Instagram or Facebook Messenger:
      📘 Facebook: https://www.facebook.com/virginmedia/
      📸 Instagram: VirginMedia
      You can also find more ways to get in touch with us here:
      👉 http://virg.in/contactvm
      Thanks for your patience, and we’ll be back on the forum as soon as we can.
      Nathan
  • Roger_Gooner's avatar
    Roger_Gooner
    Connect one pod with an Ethernet cable and disconnect the other two. If stable (after a few days at most), reintroduce pods one at a time, ideally wired, to see which one causes problems.
    • Steven_L's avatar
      Steven_L
      Hello Vim1965,
      Welcome to the Community, and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re experiencing with your Hub 5 at the moment.
      Has the advice from Roger_Gooner, helped to resolve your issues, or do you need further assistance?
      Kind Regards,
      Steven_L
  • Vim1965's avatar
    Vim1965
  • Tudor's avatar
    Do Ethernet cabled devices also loose connection?
  • legacy1's avatar
    All hubs and pods are terrible just send the pod back get your own wifi router with 1Gb or 2.5Gb ports for better wifi in your home with the hub in modem mode.
