PurpleSam's avatar
PurpleSam
3 days ago
Accessing settings in my hub 5
Since having my wifi upgraded I have managed to reconnect all my smart plugs but I have 3 smart bulbs which aren’t connecting. I’m trying to access the hub settings to temporarily turn of the 5ghz as these bulbs will only connect to 2.5ghz my problem is the hub password printed on the bottom of the hub isn’t working. Keeps saying it’s incorrect.
1 Reply
  • legacy1's avatar
    Less time wasted if you look to get your own wifi router and use hub in modem mode.
    or get new smart bulbs with WPA3 support they must work
