RYANHOWIE's avatar
RYANHOWIE
100% packetloss
For the last week i have had 100% packetloss no fewer than 5 times whilst my xbox series x is the only device using wifi. My hub has had 5 factory resets, aswell as app based resets that looked like they had fixed the issue until the following night, where it happened again. Not even peak times. Can't even stream disney+ on its lowest settings. Please help as I'm on 1gb broadband package and I'm not getting what I'm paying for.
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there RYANHOWIE
    I am so sorry that you have faced this issue with your service and thank you again for your post. Can I ask if you are noticing issues on any other devices other than the Xbox?
    100% packet loss reports from an XBOX are often a fault on the Microsoft XBOX test servers.
    The XBOX server is not returning the test traffic
    Use the link below to check the VM service speed...
    Once the test begins click on: Run full test to see Packet Loss / Jitter / Latency / Upstream speed.
    Share a screen shot of the results.
