- Steven_L
Hey sharonamiller,
Welcome to the community and thanks for taking the time to post your issue on the forums.
I'm sorry to hear of the issues that you're having with your sound beam since the change from your V6 box to 360.
Are you still having the issues at the moment? I ask this as our response is a bit late, which I apologise for but I'm happy to help now.
Have you tried to change the sound settings within the box settings? Have you tried to consult sonos to see if they have any advice that they could offer?
Regards,
Steven_L
- sharonamillerJoining in
Hi Steven
I have tried removing Dolby from the box but without success as this made no difference. I did contact Sonos but they only told me that Sonos runs on 2.4ghz but Virgin tells me the Superhub 4 has both 2.4 and 5 so I'm assuming the Sonos will connect to the correct one.
This is very frustrating as we had no problems for 2 years until Virgin updated the modem.
Any other ideas we could try will be much appreciated.
Sharon
- Akua_A
Thank you for your response sharonamiller.
Sorry to hear the problem persists. Have you tried splitting the WIFI bands as seen here to see if it helps https://www.virginmedia.com/help/virgin-media-changing-your-hubs-wireless-channel.
- HarrodinioOn our wavelength
I have had exactly the same problem. My Sonos Beam and two Ones worked perfectly until I 'upgradef' to 360. Now randomly, the sound just cuts out and the only way to get it back is to switch the TV off and on again. Some times it will go an hour before cutting off, other times just a few seconds. I've added the Sonos Boost and also removed a WiFi extender, thinking the problem could be interference but the system never missed a beat before the upgrade. It's very frustrating.
- Paulina_ZForum Team (Retired)
Hi Harrodinio,
Welcome to our Community Forums! Thank you for your first post and I'm sorry to hear that you're having the same issue as the original poster!
Have you been able to read through the thread and followed the instructions that my colleague advised? Have you tried Splitting Your WiFi Bands to see if this can help resolve your issue?
Please give it a go and let us know how you get on.
Thank you.
I don't have a computer that can be wired via the ethernet. I'm due to receive the new Hub 5 next week so I'll await that before doing any further tampering.
However, everything worked fine before the V6 box upgrade so I'm at a loss as to why this fault has suddenly reared its head.
Online chat with customer services revolved around switch it off and back on again which proved utterly fruitless.
If it comes to it, I'll have to downgrade back to a V6 box as the 360 is unwatchable at the minute.
Related Content
- 2 years ago
- 2 years ago
- 4 years ago
