Jarrc4
  • 11
Message 21 of 351
Re: Audio Sync problem with new 360 box
Did this fix all channels I am currently watching a program we recorded the other day on bbc 2 and its out of sync
I still think we should be able to shift negative and positive
hopefully VM can address this issue soon as this has really ruined the upgrade experience
roy247
  • 3.3K
  • 284
  • 772
Wise owl
Message 22 of 351
Hi Jarrc4,
This will depend on how everything is connected, the TV360 will only add delay as the video can take different time's to process through a TV depending on the TV's picture settings. I originally had my previous box going through the TV so I could adjust the delay better, now the sound is going straight into the Sony Amp and the TV360 can adjust the delay, about the only thing the V6Tivo couldn't do. Depending on how you you have everything set up is it possible your TV is adding delay that can be adjusted on the TV and not on the TV360. I think my Samsung defaults to 120mS if you play the sound through that.
hafizahmed
  • 15
Message 23 of 351
I have excatly the same issue , sound goes , picture stays and sound returns in a minute or two distorted for a few more seconds (30) then returns to normal.
roy247
  • 3.3K
  • 284
  • 772
Wise owl
Message 24 of 351
That sounds like a completely different problem, maybe you should start a new post.
tafrock
  • 137
  • 47
Superfast
Message 25 of 351
I had this exact sound breakup problem almost dalek like for a few seconds then sound returned to normal before drifting back out of sync and repeating as infinitum. I changed the convert to dolby to follow content. Got rid of dalek sounds but sync still plays up on recorded and live tv
Jarrc4
  • 11
Message 26 of 351
Thanks roy247
turning Dolby to disable seems to give best results also able to adjust sync on both TV and Samsung sound bar
may try inputting 360 direct to TV and bypass the bar as a test
as others mention we had no issue before upgrading so pretty frustrating that you possibly have to adjust so many settings depending on channel your watching
Thanks for the tips
Ahmedf6
Message 27 of 351
Im having the same issue with audio sync. My tv is Panasonic and soundbar is Sony. The setup is soundbar to tv via hdmi arc, 360 box to tv. additionally the remote volume deactivates time-to-time and I have to re-pair. Really frustrating, as the engineers are now saying its a software issue, not a hardware. It worked perfectly fine before upgrading.
waiting to hear on what the next steps are regarding this from virgin.
Tags (1)
tafrock
  • 137
  • 47
Superfast
Message 28 of 351
To solve this you must connect direct from 360 box to amp
I do this using optical from virgin box to Sony ht3 amp
I connect hdmi from virgin box to Sony bravia TV (hdmi socket not hdmi arc)
I have No connection from amp to TV. This causes the sync problem
Follow my steps and it should solve all audio problems
Ahmedf6
Message 29 of 351
optical connection via vbox to tv or tv to amp works fine. Its a setup ive used before HDMI ARC was introduced.
The problem with this setup is you now need to use 2 remote to control sound. Unless, you’re setup allows that. A step backwards in comparison to all other boxes, including the old v6 box.
guess virgin have to step up with firmware updates pretty quick.
luk34dd0
  • 78
  • 19
Dialled in
Message 30 of 351
Same issue for me.  The issue is with Dolby audio.  If it's switched on then there an audio sync issue.  Switched off in the settings and the issue has gone (but things sound worse).
I use HDMI ARC from the TV to the soundbar.
Changing Audio Sync just makes the problem worse because you can only + it.  The sync issue needs to be -.
Virgin TV 360 + Virgin TV 360 Mini
Gig1 > Hub 4 in Modem Mode > Taotronics Mesh Wi-Fi
