1 Reply
- roy247Hero
Hi Giova47,
As long as the box is working OK I wouldn't bother too much. Is it exactly the same colour on and off, my box white light is getting redder, also some users previously have posted after a software update to the box this has happened and then another update has magically fixed it.
Virgin are rolling out version 5.09, if you press the Home button and go to Settings (the cog wheel) and then Info you should see what version software your box has, I am still on version 5.08.
Related Content
- 4 months ago
- 3 months ago
- 1 year ago
- 7 months ago
- 2 years ago
