25-01-2024 00:32 - edited 25-01-2024 00:37
Hi All,
So I've been on the new GSX-PON FTTP (Fibre to the Premises) connection since October. The first month and a bit was fine with no issues however since at least November I have had issues with latency spikes noticeable when gaming. I set up a Broadband Quality monitor and have also been running various latency tests and it seems that my broadband consistently had a pattern of peaking to very high latency and also when in use and gaming more of these latency spikes occur. I'm not talking spikes to like 60ms, I am seeing spikes up to well over 500ms.
On the tests I run the latency on download is fine however on upload most of the time it will see an average of around 150-350ms latency. On the rare occasions, I do see this stay around 20-40ms on tests but I'd say 90% of my tests show over 200ms on upload latency.
This seems to be down to bufferbloat however there is nothing I can try on my side to sort this out as the Hub 5x cannot yet be put into Modem mode so I can not buy and use my own router with some SQM to help stop bufferbloat. However, that is beyond the point as my old ADSL line never had these issues and there was no special SQM on that. I should not need to buy a router when this is not acceptable broadband that should not be having these issues.
I've had an engineer out who replaced the Hub 5x and also cleaned my fiber cables inside and the one outside connecting into my house. The one on the pole has not been done yet although I am told by the engineer that a request for a new line to be sent from the pole to my house has been sent, this has only been up since October so I don't think this will solve the issue but we will see.
Is there anyone else on the new GSX-PON network using a Hub 5x who can share their results on BQM and other tests so I can compare? I feel like Virgin Media's new network has an issue with the upload latency and I can see this being annoying for them to try and fix which they really need to do.
Also for your info, I get the exact same results with the Wi-Fi turned off on the Hub and all my network devices disconnected from the hub. I still get the fluctuating results with 1 Laptop connected directly into the Hub with nothing else connected to the network at all.
I've included examples below with also the rare good test I actually got to prove that it isnt just the test bloating the network as sometimes it has perfect upload latency but only 5% of the time I test it. If that.
Broadband Quality Monitor
Bufferbloat Test
Cloudflare Test 1
Cloudflare Test 2 *This is what I get the majority of the time*
26-01-2024 01:22 - edited 26-01-2024 01:25
Sharing my results for you
on 26-01-2024 02:08
I can’t see the pictures yet, did you make sure to blank out IP address?
26-01-2024 23:16 - edited 26-01-2024 23:20
Yes all blanked out, re-adding here, (they still showing above for me)
added below works fine. (maybe)
on 26-01-2024 23:19
trying again...
on 26-01-2024 23:38
Can see them all now mate, look like better than mine
on 27-01-2024 00:43
seems so, still an issue with the upload with Bufferboat but I don't notice anything on games, I'm on the 2gig package aswell.
on 27-01-2024 09:09
are you only on the 250 package or testing over wifi?
on 27-01-2024 10:09
Yes on the 250 package and it has high upload latency when on a wired connection on tests. Should not make a difference what speed I’m on for upload latency
27-01-2024 14:11 - edited 27-01-2024 14:13
My Bufferboat looks great on a slow connection
https://www.waveform.com/tools/bufferbloat?test-id=1671fed3-ffca-46d1-b9c2-076d2164cf86
on 27-01-2024 14:35
Is this using a Hub 5x as well?
