Gigabyte speed issue
thewickedpicket
Hello
I recently upgraded to gigabyte from M500. I run the hub 5 in modem mode and use an ASUS router for WiFi.
the speeds I am getting are only slightly better than M500. Around 600 using the ASUS wired speed test facility. WiFi speeds are also only slightly better.
I installed the hub myself and I assume there is an issue somewhere with the connection coming into the house?  Can someone contact me about this?
6 REPLIES 6
test speed by wire not the speed test on router
disable QoS/BWM on your router
Thanks QoS is disabled. And the speed test was the same when I installed the new hub and tested directly from it. The ASUS router also has a feature that tells you the speed it’s getting from the modem. It’s never been much above 600mb
Run the FULL tests on this site and post the results please
www.samknows.com/realspeed
Roger_Gooner
You cannot get 600Mbps from M500, for that sort of speed you need at least M600.
Note: My username is Roger_Gooner and not Alessandro Volta
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Sam knows won’t work for some reason?
It requires the HUB to be in router mode.
