- nodrogdVery Insightful Person
I have created a new thread with your post so you can be dealt with individually. Piggy backing on someone elses will only cause confusion.
- Kath_P
Hi MrsTWright,
We're very sorry to hear you're having some issues with your Hub 3 displaying a red light. Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red at times. This is perfectly normal and nothing to worry about.
If it's not then please follow the below steps:
- ➡ Turn the power switch off on the back of the Hub.
- ➡ Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight.
- ➡ Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the red light still shows after doing the above, pop back here and let us know. We can then arrange an engineer to visit to swap out the Hub.
Related Content
- 2 years ago
- 11 months ago
- 3 years ago
- 9 months ago
- 5 years ago
