Evelyn60's avatar
Evelyn60
4 years ago
WiFi keeps dropping out
This past five days we’ve experienced issues with our WiFi dropping out. It’s happening about every 30 minutes.  I have turned off hub/router. Have turned off devices , tried all suggested checks etc and still having issues.  We had no problem whatsoever until a few days ago.  It’s both annoying and frustrating. Could be in middle of something and get the dreaded you are no longer connected to Internet.  Any hints or tips appreciated but not too technical please.  I’m not tech savvy unfortunately.  Many thanks.
  • g0akc's avatar
    g0akc
    Problem sorter
    Are wired connections okay?
    • Evelyn60's avatar
      Evelyn60
      Thank you. Yes have checked and all seem fine.
      • Ayisha_B's avatar
        Ayisha_B
        Hi Evelyn60,
        Welcome back to our Community Forums and thanks for posting.
        I am sorry to hear you've been having some issues with the service. I appreciate it can be incredibly frustrating!
        I have taken a look into this and our systems have identified you have been experiencing network issues over the last week which can cause intermittent or performance related issues. Can you please check that the coax cable is connected securely to the Virgin Media equipment, any splitters (standard and powered) and to the wall socket? If after checking the cables, there's no improvements, let me know as a technician will be required.
        Please keep us posted so we can offer further support if needed.
    • g0akc's avatar
      g0akc
      Problem sorter
      If wired is ok it suggests the connection to your house is working well but there’s a problem with the WiFi within the home.
      Hard to say what is causing it to drop every half hour - likely a software bug but could also be interference from neighbours WiFi, baby monitor or whatever.
      • try using a free WiFi analyser app to check for clashing with your neighbours, SSID disappearing and so on.
      • take WiFi off automatic in hub settings - try a different channel (1,6 or 11 on 2.4GHz)
      • factory reset hub if not already tried - long pinhole press then let it boot up and settle
      • ultimately look at getting your own wireless router or mesh and use hub in modem mode
  • I am experiencing this same issue. I've tried numerous ways to resolve it and Virgin are absolutely useless.
  • I am also having this issue since Virgin made "improvements" over the past week. Previously no issues but now the internet drops out almost every day. It seems to be triggered when I turn on my Roku TV. Never had an issue before, and it is very frustrating.
    • David_Bn's avatar
      David_Bn
      Thanks for your post notablenews, and I'm sorry to hear of the recent issues experienced with the connection after we have attempted to improve the services.
      Can you confirm if you have been able to attempt a pin hole reset on the hub since the work has been completed?
      Do you also have any issues with devices that are connected via an Ethernet cable?
      Kindest regards,
      David_Bn
      • notablenews's avatar
        notablenews
        I have done a pin hole reset a few times, but I am still having the issue.
        Nothing is connected via ethernet cables.
        Everything seems to work well until I try to stream something on my Roku TV. A few minutes after the stream starts, the TV will say it lost connection and all of my devices will disconnect from the Hub. It often takes several minutes for devices to be able to reconnect to the hub, even though I can see my network listed in the available networks. When I look at the Router Status, there is no log of a disconnect or loss of connection even though nothing can connect.
        I never had any issues until about 2 weeks ago after "maintenance" in my area.
  • Hi,
    We are having the same issue with wifi dropping out. We have tried the following:
    - Put the router out the way of any potential interference it is on the window sill in the front room. (The only thing next to it is our hive hub which works fine and we had interference which BT broadbad when we was with them)
    - Changed SSID to our own personal name (do this with every other router with no problems)
    - Manually changed the channel and turned off the "smart" settings.
    - plugged in what ever we can via ethernet to free up bandwith
    - purchased a wifi booster and put in the room where we had a "dead zone" (with all providers) and have had this turned on and off incase its causing interference or making the signal too strong.
    - Reset the router multiple times.
    The wifi will randomly drop off for 5ish minutes and just not work, all wired devices seem fine.
    Items on the network (wireless):
    - my laptop (about 5 years old) this is infrequently used so isn't always connected
    - partners laptop (about 2 years old) this is infrequestly used so isn't always connected
    - my Samsung Galaxy fold 4 (about 3 months old) (connected when home)
    - partners Iphone 12 (about 1 year old) (connected when home)
    - 3x amazon echo's in various rooms (always connected)
    - wifi printer (always on)
    - 2x fire tv dongles (rarely used)
    - ring door bell  (about a year old)
    - ezviz floodlight cam (this can only run on 2.4ghz network)
    Connected wired:
    - fire tv (about 6 months old)
    - hive (about 5 years old)
    As you can see the age of the products vary and are all having the same issues, we have just moved from BT to Virgin and had no WIFI connection issues whilst with them.
    We have the Hub 3 and missed out on the free hub 4 upgrade offered to customers.
    My only other suggestions would be to try a new router (hub 4) or for me to buy another router and put the hub 3 into modem mode, but I shouldn't have to do this.
    I'm more than happy to try other suggestions from other members or Virgin directly. However you can see I think I have exhausted other routes.
    Apologies for such a long message, would rather give too much info than too little.
    Thank you
    Nathan
    • Nathan-91's avatar
      Nathan-91
      Also worth adding that the wifi shows as still connected, just no internet connectivity
  • markyboy72's avatar
    markyboy72
    beeb with virgin for 15+ years and never had  problems with bb connection however last night the connection dropped. Reset everything and it eventually came back on. Then it dropped again. Reset and it came back on. All throughout the day today I’ve had the same issue, it’s ok, then it drops, reset and it’s ok again. Called virgin and they don’t see any issues with my line but I beg to differ! Is there anyway I can get this tested?
    thanks
    mark
    • Akua_A's avatar
      Akua_A
      Hi markyboy72,
      Welcome back to our community forums and sorry to hear about your recent disconnection issues.
      I can understand the inconvenience caused and want to best help. I have had a look into your service and everything seems fine hub-wise. Have you been having these issues since the last posting?
  • Just had a read through these issues and I am experiencing the same problems. When the internet is working, the speed is good but I am getting constant Wi-Fi drop outs. All around the house, on every device, phones, iPads, laptops and PCs, wired connections are fine, my daughter cannot use her iPad, my son cannot play on his PC, drop outs occur every 15-30 minutes and last 30 seconds - 1 minute. So frustrating, the dreaded ‘you’re not connected to the internet’ appears multiple times. Has anyone got a confirmed fix? Or can a virgin media team member advise me? I have ordered two pods already, reset the router multiple times. I’ve only been with Virgin for  2 months and I’ve never been moaned at so much by my children before!
    • Chris_W1's avatar
      Chris_W1
      Hi Bench8245, thanks for the message and welcome back to the forums.
      I am sorry to hear that there is an issue with the connection and can see that there is a visit planned tomorrow.
      Can you let us know how it goes tomorrow and if you are still having issues with the service?
      Kind regards, Chris.
      • Garyhobbs1's avatar
        Garyhobbs1
        Hi I’m having the same problems, kids phones and iPad dropping out speed check is ok. I will ring virgin asap
    • Molly_T's avatar
      Molly_T
      Hi Garyhobbs1 👋 welcome back to community! Thank you for posting.
      Sorry to hear you are experiencing some issues with your Wi-Fi coverage and devices disconnecting. I've had a little look into this for you and it does seem that there are no issues happening in the area which would be affecting your connection, and no speed issues for your package either. (These are averaging 381mpbs download and 37mpbs upload in the past month.) This does support the idea that the issues here are currently Wi-Fi coverage. Have you ever used our connect app 👉 https://virg.in/connectapp to help scan for black spots of coverage in the home, and run diagnostics?
      I will send you a PM to confirm a few account details so we can investigate these Wi-Fi issues and offer further support! You can find this in the top right corner of the page in your Inbox. We can then return to this public thread with another update when possible! Thanks for your patience in the meantime! All the best. 🌞
      • ceejay1952's avatar
        ceejay1952
        Since moving house in June the WiFi on our router has been pretty poor and is now dropping a signal every 30 minutes.
        checked forums and did a diagnostic check which came up with this, see screen shot.
        Can I get a new router as the current one is useless?
        My Sky glass TV works okay via Ethernet cable but Sky pucks just keep freezing.
