Unable to disable SSID Broadcasting on Hub 3
Alan_H
I've just had a Hub 3 installed, replacing a Super Hub 2ac, to allow connection of my home phone service to the fibre network.
I've been setting things up and find I'm unable to disable SSID Broadcasting the option is greyed out in Hub3 Setting Advanced Settings -> Wireless -> Security. Is there something I can change so that I can alter the setting please?
53 REPLIES 53
Hi @Alan_H
Please try the following
Advanced Settings -> Wireless -> Wireless Signal
Click on Disable Channel Optimization and then on Apply changes.
Then go back to Advanced Settings -> Wireless -> Security and you should be able to click the No box next to WiFi Network Name (SSID) broadcast
Dave
The do's and don'ts.
Alan_H
Thanks but it doesn't help, the option is still greyed out.
1) I think you probably need to turn off smart/intelligent WiFi first
2) Why do you want to turn off the WiFi?
Alan_H
Thanks.
1. Is that not the "Disable Channel Optimisation" suggested by newappollo? That didn't work unfortunately, the boxes were still greyed out. Any further suggestions you have will be much appreciated.
2. It's something I've always done, since the very first router I ever had. I know it won't/can't stop a determined person from finding it, but it does mean that those who live around me don't know how many different networks, and their names, I have in my house. Where possible I prefer wired connections rather than wifi, so I have personal routers in the 3 rooms I use most (living room, kitchen and bedroom) that I can wire devices into. Only my phone uses wifi.
Hi Alan_H,
Thanks for your post and welcome back to the Forums.
I'm sorry to hear you're having trouble disabling the SSID broadcast. Information here should help you to disable this.
Please pop back and let us know how you get on.
Kath_F
Alan_H
Hi Kath_F,
This is what I've already tried, and the option is greyed out, as per the below.
Alan
Hey Alan_H, thank you for letting us know I am sorry you are still having trouble disabling this.
I am going to send you a PM, as I can help you do this.
Please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
I'm having the same issue, I've switched off Smart Wifi and still unable to disable SSID broadcasting
Hey @gforgabagool, thanks for reaching out to us and a warm welcome to the Virgin Media forums.
I'm sorry to hear you're struggling to disable the broadcasting SSID on the Virgin Media Hub 3.
I have attached a video here which shows how to alter, change, split and disable the SSID.
Let us know how it goes and if you still need assistance.
Kind regards.
Ilyas_Y
