Cmd_'s avatar
Cmd_
11 months ago
UPS for HUB5
I am looking for some advice on what UPS I can get for my HUB5 due to some annoying power cuts my area can experience.
I already own this for my PC:
https://www.cyberpower.com/uk/en/product/sku/cp1300epfclcd-uk
but this is setup completely out of reach for where the modem is so I was thinking about these mini UPS that would just be for the modem alone & which one would actually work with the HUB5 with regards to voltage & connections to the unit itself with the right adapter from my modem to the unit. I found these on amazon but I'm not sure if one of them could be compatible with the HUB5:
https://www.amazon.co.uk/Mini-10400mAh-Router-Battery-Backup/dp/B0CNT6LLHP?dib
https://www.amazon.co.uk/APC-Back-UPS-Connect-Lithium-Ion-Controllers-White/dp/B0CJ5D89Z9?dib=
If anyone here has done something similar with their HUB5 having its own 'mini UPS' I'm very interested to hear what you purchased that worked.
    • Cmd_'s avatar
      Cmd_
      Thanks I will take this in to consideration.
    • Cmd_'s avatar
      Cmd_
      I presume the street cabinets don't have a UPS, but a UPS for the modem itself can not only maintain the connection but also protect it from any possible damage caused by power surges when power is returned or repeated on-and-off cycles when power cuts happen. Sometimes, it's not just one cut & the power returns it can be on and off multiple times right after each other, which I figure might not be good for the modem
        I have all my kit on an APC UPS.  Mainly because we get the occasional brown out.  Otherwise we would have some kit restarting from the voltage drops.
  • legacy1's avatar
    The problem with mini UPS will be finding the adapter so you may have to get a full size UPS
    A UPS that produces mains voltage is very easy to re-purpose.
    We can't know what VM Hub model or RFoG ONT PSUs might be issued in the future to get us back online.
