Kishorv's avatar
Kishorv
Red light on hub
My broadband hub has a solid red light.  Tried pin reset, switching it on and off.  Comes back as solid red light.  It's in an open area plenty of ventilation.  Slightly warm but not that bad.  Any thoughts ?
  • Hi Kishorv, thanks for getting back to me privately.
    This is just a quick note to confirm you're satisfied with the response and efforts of the forum team? Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand. Please bear in mind, you can manage your account from here. Your online account, will give you access to your bills, show your package details, diagnose any possible faults and monitor any orders and appointments you may have.
    Lee_R
    Is my Hub 3 hot or not ?
    To check login in to the Hub 3 menu at http://192.168.0.1/
    use the numeric Hub password from the bottom side label.   ( this is not the Wi-Fi password )
    Run the Network diagnostic tool
    Scroll down through the results and find the Temperature entry.   Is it:  Normal  ?
  • Hi Kishorv thanks for posting and welcome to our community.
    Sorry to hear of the constant red light of your hub. And for any concerns this may be causing. I'd love to take a look on your behalf. I'm going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
    Lee_R
    Lee_R
