- Client62Alessandro Volta
From the Hub menu, run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ? - Dan-C06Joining in
Experiencing exactly the same issue, internet working all ok, hub doesn't seem hot, just slightly warm
I phoned Virgin and was told not to worry? I then run the service status on the website, then telling me they checking my equipment and found an issue and they looking into it and for me to check back after 24hrs.....I've gone through that all before with another issue!!
From what I've been reading elsewhere it seems a overheating issue, that is concerning but can't believe Virgin don't want to send an engineer or a new hub out.
- AdduxiVery Insightful Person
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
- Martin_N
Hi Mike7275,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the red light on the hub.
We can certainly take a look into this for your.
I will private message you now to confirm your details.
^Martin
Related Content
- 2 years ago
- 4 months ago
- 3 years ago
- 4 years ago
- 1 year ago
