on 20-01-2024 21:44
There is a red light on our hub. I have tried turning it on and off and a pin hole reset. Is there anything else I can do to rectify this?
Thanks very much.
on 21-01-2024 11:43
Is it a Hub3?
on 21-01-2024 14:51
Hi Carrick36 👋🏼.
Thank you for posting, welcoming you onto the community forum 😊.
Sorry to see you have had a red light on your hub ☹.
Thank you for trying the factory reset (pin hole reset), I can further investigate 🧐 for you and see what is is going on.
I will have to private message you, please watch out for the envelope ✉.
Ari - Forum Team
