Red light on hub
JulioV
Hi guys , my hub is showing a red light for the last 2 weeks, before used to be white. I reset it and still no change, also if I go into the bedroom, literally a paper thin wall away the signal keeps dropping on my mobile. Anyone can help? I tried VM but with no results as I can't seem to speak to a human.
Thank you I'm advance.
2 REPLIES 2
Joseph_B
Hey @JulioV,
Welcome to the Community Forums and thanks for the post.
Sorry to hear you are having this issue, we would like to go about getting a technician out for you to go about looking into replacing your Hub for you, for this we will need to confirm some information from you via private message.
Joe
Sure that would be great thanks
