- Mr-DiceOn our wavelength
Don't get the Hub 4 whatever they tell you .
- SephirothAlessandro Volta
Hub 4 is fine. I’ve had one for 4+ years. It’s the CONNECT app that screws up the Hub 4 (unable to access the Hub 4 GUI).
- Client62Alessandro Volta
Is my Hub 3 Hot or not ?
Note: a Hub 3 in Modem mode has a Magenta bar & usually Warm White in Router mode.
This can just be the LED is fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/ use the numeric Hub Password from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ? - Steven_L
Hey mitch34,
Welcome back to the community and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your router at the moment. I have been able to locate your account and can see that you have been able to get an engineer visit booked in to investigate this further. If you get the chance, please let us know how it goes 👍
Kind Regards,
Steven_L
Related Content
- 2 years ago
- 3 years ago
- 5 years ago
- 7 months ago
- 1 year ago
